How much HP can a 2 bolt block handle? >
Old 10-28-2012 | 04:58 PM
I have come across a few 340 MIE engines that had 2 bolt blocks, so it is possible that it is a 2 bolt.
Eddie
Young Performance is offline
Old 10-29-2012 | 05:43 AM
When I wiped out the motor in my first baja we pulled it and it was a 2 bolt block. Built a 496 out of it and studded the mains. It made almost 600hp And did not have any issues with the bottom end, it did however split a cylinder wide open one day and destroyed everything!!!
I think your best bet is to find a newer block with no chance of being rotted internally if your looking to build something requiring you to take a good bit of metal out of the cylinders!
Baja226sport is offline
Old 10-29-2012 | 06:36 AM
seen many 330 with 2 bolts, have a std bore 4 bolt gen IV bare block if you need
ezstriper is offline
Old 10-29-2012 | 08:57 PM
If it does end up being a 4 bolt and I try to keep it what is a rough estimate of how much sonic testing costs? Would it still be better to find a newer block?
Sunrocket24 is offline
Old 10-30-2012 | 07:53 AM
The block i used that split open was a fresh water motor. But unless you had a closed cooling system on it I would definitely have it checked out before building.
Old 10-30-2012 | 08:33 AM
Fenderjack's Avatar
Pirate of the Chesapeake
2 bolt motors can handle some hp,back in the day seemed like the best running motors were 2 bolts. Ran a stroked 2 bolt in the drag boat for years NO ISSUES. JOHN SR
Fenderjack is offline
Old 10-30-2012 | 10:23 AM
Sonic testing $150-250.
picklenjim is offline
