-   -   What pistons come in a 502 mag? (https://www.offshoreonly.com/forums/general-q/287263-what-pistons-come-502-mag.html)
cp5899 11-01-2012 08:33 PM
Like the title says. I just disassembled my 502 mag that was supposedly rebuilt 70 hours ago. The pistons look good, but they are je flat tops with one intake valve relief. For some reason I thought the 502 mag came with a small dome piston. The motor is 30 over.
Our Scarab 34 11-01-2012 11:07 PM
502 Dome
Yep,
the few 502 Mag from factory i have torn down are JE and have a small dome on them with valve relief.
Did you do a compression check before the tear down? Maybe the block & heads were decked below quench area.
Others can probaly help more.
Aaron
Young Performance 11-02-2012 12:37 AM
Yes, the factory pistons are a mini dome.
Eddie
cp5899 11-02-2012 06:58 AM
These pistons are in great shape with no wear on the skirts at all, but I don't think the flat tops are going to help me get to my 600hp n/a goal.
Does anyone know of a replacement piston part number? Or even what size the dome is on the stock piston?
F-2 Speedy 11-02-2012 07:11 AM
the JE700's I just pulled out of my 502 Mag look to be 10cc, and they are for sale with dimple rods connected :D
cp5899 11-02-2012 07:50 AM
What's the bore? I'm on 30 over now.
F-2 Speedy 11-02-2012 08:14 AM
Std
ezstriper 11-02-2012 09:51 AM
I can use the pistons you have if you want to get rid of them....need some 502 + and flat tops are fine with me with a procharger.../[email protected] thanks Rob
Young Performance 11-02-2012 10:55 AM
The stock pistons have a .050 dome with a valve relief. THey total 1 cc. JE has a small dome piston with a 10 cc dome that will get you where you need to be.
Eddie
