-   -   Looking for ECU advice (https://www.offshoreonly.com/forums/general-q/287737-looking-ecu-advice.html)
articfriends 11-17-2012 05:36 PM
What kinda boat is this going in, its one thing to drive around at 75 or 80 mph doing a tune vs 100+? The problem with tuning on the water with something that is on the edge is its hard to get "clean" safe water and do wot runs to tune things in safely . A self tuning ecu like Haxby is talking about would be a big plus for what you want to do but not a absolute neccesity. I feel bigger hp blown motors should be tuned on the dyno as there is so much going on when your boosting something and so many variables that how would you know for sure that your making max hp while dodging things in the water at 100 + mph and keep in mind if motor goes lean under boost and you don't catch it fast enough it doesn't take long to turn pistons into Souvenirs (they make great ashtrays for your buddys that smoke), Smitty
articfriends 11-17-2012 05:37 PM
Originally Posted by southbenz (Post 3816998)
The ECU I have is the same one that came with the motor in 04, Im not sure which one that is. I live in Beaumont TX area. I was just thinking if I had a setup with a wideban like the Holley set up I could tune it myself. I do agree that there is no better way to tune any motor than to put it on a dyno, and if I have to I will do that. Ive had race cars but they were carburated and I can tune them but Im new to the EFI systems. Thank you guys for your help and input
Post the part number off your ecu and we will tell you what it is, Smitty
Young Performance 11-17-2012 05:54 PM
If the ecm is square (about 3" x 3") and has the plugs going into the top of it and has the 8 digit # ending in 099 or 999 it is a Mefi 3.
Eddie
southbenz 11-17-2012 06:52 PM
This setup is in a 04 26 American Offshore. Eddie I dont have my ECU mith me, Im waiting for it to come back from ASM but I think it is the Mefi 3. The pluggs are on top like you said. The boat will run 98 with a 30 pitch labed 4 blade and only making 2lbs boost @ 5400 rpms. Im planning on setting it at 8 lbs then doing some prop work. It never was tuned or the correct prop to begin with. Im sure ill end up going to a diffrent outdrive from the bravo xr and IMCO lower with 1.5 gears. My goal is to break 100 on a conservative tune. Bob I might give you a shout when I can get off this turnaround...
01scarab29 11-19-2012 10:41 AM
I also live in Beaumont, have you talked to any of the guys with powerboats there ? do you know George ,, Ronald or Regan ,, Mark ,, B.J. ? George gave me a couple of names, Crocket Marine in Ruby, MI. 810-324-2720 ,, Precision Marine in Kenner, LA. (504) 469-7463 ,, Full Throttle Marine in Spicewood TX. (830) 693-5591. I've spoken with all three several times. i'm taking mine to Full Throttle because Crocket is just to far and Precision mainly deals with Big Blocks. I'm going from 350MPI to 383MPI with several changes
. i am getting them dyno. i also have MEFI 3,,,
01scarab29 11-19-2012 10:43 AM
sorry for last post guys ,, went to wrong post
01scarab29 11-19-2012 10:45 AM
ezstriper 11-23-2012 09:30 AM
without wanting to piss anybody off...I would get rid of all the merc junk...worthless for what you are trying to do...to many good EFI systems out there now that you can tune...unlike the merc junk..
