trim pump resevoir, where to get >
Old 11-21-2012 | 07:19 PM
You can get them several places. CP Performance, Keith Eickert, Teague, Diamond.
http://www.keitheickert.com/c-766-reservoir-tanks.aspx
picklenjim is offline
Old 11-26-2012 | 07:50 AM
Since were on the subject...
Has any one seen or know where to get a larger reservoir for a barnett trim tab pump? The issue is mine (stock one) dosent hold enough oil for the 2 hydraulic cylinders that lift up my hatch.
92nsx is offline
Old 11-26-2012 | 11:14 AM
Mine are made by get real and they are amazing. The quality is top notch. I just really wanted to clean up the engine bay and since I have a single engine boat the triple worked perfect.
I bet if you called get real they would be able to make you one with a larger tank.
There power steering and drive reservoirs are super nice too.
[IMG][/IMG]
http://getrealperformance.com/marine...eProducts5.php
86Capri is offline
