Procharger lossing boost at 5400rpm???!!!! >
Old 11-21-2012 | 12:16 AM
Default fixx
all good info,,just for chits pull off the hose going to the front of the blower and see if theirs any fins left on the blower..
FIXX is offline
Old 11-21-2012 | 02:41 PM
Scarab28's Avatar
Save a lotta time, get a new tensioner and belt. Been there.
Scarab28 is offline
Old 11-21-2012 | 03:56 PM
you swapped blowers and carbs and it made no difference, sparks not dropping, valve float
J. Hordubay is offline
Old 11-21-2012 | 05:48 PM
I cant see if being valve float at 5300, unless you had valve springs from a flat tappet 330 Merc in it. lol
Check the tensioner operation. Also, You may want to add a idler pulley.
[youtube]http://www.youtube.com/watch?v=XJ1I_NtxVK0&list=UUoyUg1bQZ8ptd9AKYkI_M3A& index=9&feature=plpp_video[/youtube]
MILD THUNDER is offline
Old 11-21-2012 | 09:17 PM
We might go out one more time. Going to put a new belt on it and tighten up the tensioner. If that doesn't work check the springs. The blower looks perfect switched them from motor to motor and that motor still has the same problem.
excalibur82 is offline
