500 efi long block replacement >
Old 01-06-2013 | 08:33 AM
Steel Outlawed's Avatar
Originally Posted by Redeye
Hello again Guys and thanks for your input.
I have puchased a GM Marine 502 HO longblock
I want to back to or as close as possible to the original 500 EFI specs
Can someone reccomend who I should have work on my Heads?
I live in Washington state and it would be great if I was able to do it local
any other advice in making the motor dependable would be appreciated.
You should be able to find someone in your area that can re-work the heads. Just search for a cylinder head shop in your area. No use to ship those heavy things around the U.S. if you don't need too.
Steel Outlawed is offline
Old 01-08-2013 | 06:44 PM
if you end up needing a hp 500 efi cam,i have 2 for a gen 6 block.
mike tkach is offline
Old 01-17-2013 | 06:19 AM
thanks again for imput every oneI have another question
I am concerned about contamination {metal} in my existing oil cooler and lines are we able to clean or flush them or should they be replaced?
Redeye is offline
Old 01-17-2013 | 06:37 AM
throw the cooler in the trash,it is not worth the risk,imo.
Old 01-17-2013 | 07:01 AM
offshoredrillin's Avatar
there is a guy the did some work on 2112's gladiator, dan fitzgerald I think his name is...Fitz's marine. very nice guy,very laid back, spoke with him a couple times on another engine. He is in WA too.
offshoredrillin is offline
Old 01-21-2013 | 12:22 PM
thanks mike, I was thinking the same thing why spend all of the $ time effort and energy and risk loosing it all.
I will post some pics when we start putting her back together
taking the heads to Larson and King in portland or tomorrow
Redeye is offline
