milkey oil
Old 12-04-2012 | 02:06 PM
Ken N's Avatar
Arrow milkey oil
what causes milkey oil and 0 compression in #1cyl.
Ken N is offline
Old 12-04-2012 | 03:48 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Bad valve , cracked head and only half a piston .
the deep is online now
Old 12-04-2012 | 04:24 PM
Could be just a bad head gasket.
Flyin-Bryan is offline
Old 12-04-2012 | 04:33 PM
the deep's Avatar
Fast Singles Club
Yes but a blown head gasket usually will still show some compression . Were there any strange noises coming from that cylinder . Time for some exploratory surgery .
Old 12-04-2012 | 05:11 PM
I saw a cylinder bore with a massive crack 1/16" x 2" and it wasn't cold weather. I think it had something to do with complications with nitrous oxide.
30ftpanther is offline
Old 12-04-2012 | 05:36 PM
Pull the head off that side and I'm sure you'll find out. It's going to have to come off sooner or later anyway. Probably should just pull the entire engine and get it over with. Time's a waste'n!
picklenjim is offline
Old 12-04-2012 | 06:03 PM
Water intrusion, antifreeze, could be a few things. Typically a head gasket
07DominatorSS is offline
Old 12-04-2012 | 07:45 PM
Bad intake gasket,,if one of the corners are laeking cylinder # 1 can suck the water in,compress it and bend the connecting rod and or push rods..
FIXX is offline
Old 12-04-2012 | 08:57 PM
Expensive Date's Avatar
Raw water, small blocks, Vortec heads?
We can guess all night though, do a leak down just to see the readings then pull it apart.
Expensive Date is offline
