EXHAUST TIPS: Straight or Angle Cut?
#41
Not sure what bearing silent choice would have on the issue, unless you are thinking that the Y-pipes might prevent water from backing up the exhaust if a wake pushes it up the tailpipe. In that case, if it was a big enough wake, I would be concerned that it could still make it's way to the manifolds. I would be curious to know how much this helps.
I like the look of angle cut tips myself. Wish I could find a set of them with switchable mufflers built in. I like the option of making it quiet when I need to, or letting it roar. Still trying to figure out a way to get my Lightning headers to work with a Y-pipe. So far no dice. Lightning makes a set of switchable collectors for their headers with divorced collectors, but they are like $900 - I just don't have that kind of coin laying around.
Regarding the rubber Salisbury flappers - I think they help some, even when the tips are at an angle and they dangle open slightly. I was watching my buddy's boat that has the flappers on it last summer, and on a small swell just a little bit of water would wash up the exhaust, but not likely enough to overcome the downward angle of the exhaust. When a really big swell would hit the stern, the extra water pressure would push the flappers shut, effectively keeping the wave from washing all the way up the pipe. That being said, a lot of the tips have the internal flappers. I still like the looks of a set of shiny angled tips over the salisbury flappers any day - those things just look like they should be on a mack truck to me.
