What SS Prop for 383 stroker on 21' 3,000 lb Senza
OK, time to re-prop again.
I've got a 383 ci. stroker motor putting out 380 HP @ 5200 RPM and 450 ft-lbs torque at 3,700.
What prop would you guys recommend for a 3000 lb. total wt boat? I was running 60 mph (GPS) with a stock 5.7L 260 hp/ 21" SS Laser prop last year. Same prop shows ~ 70 mph at 5300 RPM now.
Engine is rollerized (lifters, rockers). Where should I shoot for in RPMs for this combo?
Id say you are prety close now... have you tried the vatios other types of props out there.. Like bravo 1s? In all my testing Ive always found the 3 blade to be fastest. If you should be maxing out at 5200 and you are currently hitting 5300 Id say try 1 size up. You will cruise faster and be in the fat part of the torque band .
Thanks for the help guys. Right now, I am leaning toward trying a 23" Mirage Plus, as I've heard great things about them, and a 200 RPM drop (maybe more?) would likely do me some good.
Torque of this cam in a 3,000# package is pretty fat for a small block. On the Dyno, 400 ft-lbs from ~ 2,400 - 5,000 RPM, maxing at 450 ft-lbs at 3700. Max HP is 378 w/ the Q-jet rejetted (didn't care for the Holley steady-state mid-range & idle properties while on the dyno). Holley pulled the dyno a little faster, but owner of shop steered my away from the Holley, as the Q-jet is less "High Maintenance".
Misc. question maybe someone out there can answer. Wierd thing I noticed last year when testing some Revolution 4 demo props last year. Spinning a 23" 4 -blade (all they had in stock at first), my old engine would not pull that sucker up past ~3400 RPM. Aftre getting ahold of a 19", I could spin it to ~5,000. Was I just not getting up on the curve enough to get it to within 400 RPM of the 19" Revolution 4??? Seems pretty drastic. I'm thinking I could likely spin at least a 21" Rev 4, but I need to keep the Alpha in decent shape (at least until late in the season when "Whoops...Dear, I think we blew the outdrive...Have to change to a Bravo...boy, that was good timing...just in time for winter!"
