-   -   blower (https://www.offshoreonly.com/forums/general-q/289250-blower.html)
cig20 12-24-2012 10:32 AM
blower
i have 11 inches under deck lid for block where blower will bolt is there any that will fit with out doing any cutting
Young Performance 12-24-2012 01:32 PM
An efi (axial) Whipple will certainly fit.
Eddie
cig20 12-24-2012 02:39 PM
my motor is a carb motor
blkhorse 12-24-2012 02:55 PM
maybe a centrifugal style with carb box?
Jeff P31 12-24-2012 10:46 PM
Do yourself a favor and change it to efi . If you truly are thinking of a blower, you should already know that you are going to have to make lot's of changes anyway.
cig20 12-25-2012 11:44 AM
Originally Posted by jeff p31 (Post 3837512)
do yourself a favor and change it to efi . If you truly are thinking of a blower, you should already know that you are going to have to make lot's of changes anyway.
why efi
James 12-26-2012 07:01 AM
250 blower height
Manifold from block to top gasket surface = 4 1/2"
Blower with carb = 12"
Flame arrestor = 3"
ondtip 12-26-2012 09:59 PM
A friend put a 250 blower on a 251 checkmate with a 454. It fit no problem. He blew the stock 365hp mag with the blower. Then he had a conservative blower motor built. At 6 Lbs of boost with the 250 blower he was at about 550HP. No chiller and no problems and whined like a little girl when on the boost. Sounded cool.
Jeff P31 12-26-2012 10:38 PM
Originally Posted by cig20 (Post 3837666)
why efi
Do a little home work and you might figure it out :eekdrop:
FIXX 12-27-2012 12:19 AM
cig 20,,are you going to follow through this time??? the last guy i sent you to all you did was waste his time....if your just tire kicking then please dont waste any of our time,its not going to be a 1000 $$$ job..
