Installing new motor with trans help >
Old 12-28-2012 | 12:15 AM
  #31
Originally Posted by dammmagnum
The matching engine to this one in the boat overheated from a crack block or some other issues in less then a couple of hours of running it, so check it out before buying it.
Originally Posted by MILD THUNDER
Nice part about that is when you smoke a rubber impeller, the pieces go straight into your engine and stay there forever.
May be that's what happened to the other engine!
Originally Posted by mrfixxall
yes thats normal on a bell housing set up...btw its only one cooler..the rear one is for the trans..
The rear one is for the trans true. But it's still a cooler!
picklenjim is offline
Old 12-28-2012 | 08:09 AM
  #32
Here's where my alpha gen2 still leaking
kakarot is offline
Old 12-28-2012 | 09:33 AM
  #33
Can you back out the camera and show a pic of the drive and this area?
Old 12-28-2012 | 04:13 PM
  #34
Ill post a pic later, I got a good deal on a pair of 200HP Mercury BlackMax with rigging and everything for 2700$
kakarot is offline
