-   -   Composite Dist. Gear (https://www.offshoreonly.com/forums/general-q/289570-composite-dist-gear.html)
The Get Away 01-02-2013 06:29 PM
Anyone running a composite distributor gear?
smokin' gun 01-02-2013 07:46 PM
i run them in my engines .tall decks and have had no issues they are expensive for plastic
The Get Away 01-02-2013 08:09 PM
What style cams are you running?
smokin' gun 01-02-2013 08:15 PM
comp cams camshafts ground on crane cores .dist gears are comp cams also .i changed them from the bronze to the composite
The Get Away 01-02-2013 08:30 PM
Sorry I should have been more specific about the style gear on the cam. I am trying to figure out why I am going through bronze distributor gears about every 20-30 hours of run time. I'm 99% sure that the cams are billet, and don't have the pressed on cast gear.
