Crane hi6 ignition box
Which wires goes to the distributor?
Are using the HI6 or HI6M. Are you using the hall effect TB distributor? Did you phase it?
I believe the HI6 uses the Violet (+) and Green (-) http://www.sportcompactonly.com/manu.../90006000e.pdf HI6M White/Green White/Red http://www.sportcompactonly.com/manu.../90006462b.pdf |
Rookie thanks its the marine version, i looked last night and over looked it.
This winter I am going to try to hook up a knock module and sensor. So when the module sees knock from the sensor, it will source voltage to a relay. Then the relay source (-) to the HI6M brown retard input wire and the retard ignition timing to what I set on the box.
