valves ?
Old 01-10-2013 | 07:44 AM
Default valves ?
what valves are you using in a 750hp blower motor?
sodium filled ? typical stainless ?
kennyd is offline
Old 01-10-2013 | 10:17 AM
Severe duty valves on the intake, extreme duty (Inconel) on the exhaust. Stay away from Narrow Seat width valve jobs.
MILD THUNDER is offline
Old 01-10-2013 | 10:45 AM
Manley makes an exhaust valve made from inconel alloy that is generally recommended to any high performance marine application, NA or not. A set of 8 1.88" exhaust valves will set you back $350 - $400 depending on where you buy. I found a set of Ferrea's extreme duty superalloy (same thing as inconel) online for around $285. That is about the best I could find.
Budman II is offline
Old 01-10-2013 | 11:02 AM
Full Force's Avatar
never skimp on valves, it will cost you if you do!!
Full Force is offline
Old 01-10-2013 | 11:11 AM
done , ordered them !!!
kennyd is offline
