Vacuum gauge installation 500hp carb >
Old 01-19-2013 | 02:04 PM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Originally Posted by speedfever
I bought the boat last fall. At one time in its life it had blower motors and it had fuel pressure and vacuum/boost gauges that were left in the console but are not hooked up. I want to hook these gauges up so everything works.
I like it when they read on the BOOST side !
the deep is offline
Old 01-19-2013 | 02:05 PM
Originally Posted by MILD THUNDER
I may have some fuel psi electric senders available, might go mechanical on my fuel psi.
My fuel pressure gauges are Gaffrig 0-15 psi.
speedfever is offline
if its a true hp500 use the port behind the carberator thats threaded into the manifold..
FIXX is offline
That would be nice........lol
Old 01-19-2013 | 02:06 PM
mine too
MILD THUNDER is offline
Old 01-19-2013 | 02:10 PM
the deep's Avatar
Fast Singles Club
That's the one used for the PCV valve bro . The one on the front side has a plug in it .
the deep is offline
Old 01-19-2013 | 02:29 PM
I originally posted this question at 2:30 pm today. By 3:00, I have got a bunch of replies to help me with this. This is why this is such a great website !!!!!! Thanks everyone for the replies. It looks like I have several options to check out. I will post what I find.
Old 01-20-2013 | 12:30 PM
At the very top of the intake manifold in the front there is a plug , pull it out and screw in the proper size nipple . If you use the one on the carb make sure it is located below the throttle plates . Why do you want to measure vacuum ?
I found this plug. It is right under the baseplate at the front of the carb. 3/8 npt brass plug. This is the easy fix that I am looking for to hook the gauges up. I found the brass fitting that I need at Lowes.
Thanks for the tip
jeff
Old 01-22-2013 | 06:18 AM
I have the exact same boat and setup. Fountain used the port under the front of the carburetor baseplate. Mine had 1/8" clear plastic tubing running to the guages. I removed it all so if you need anything let me know.
JoCo32 is offline
