number stamped in front of block >
Old 01-26-2013 | 01:43 PM
Default number stamped in front of block
does this number mean any thing was stamped on block above timing chain cover
107025 xk
cig20 is offline
Old 01-26-2013 | 05:55 PM
107025 xk
I think on some blocks that was like a manufacture date/plant type of code. I could be wrong
The casting number that is more important is on the rear of block, just above the bellhousing flange. Certain castings were better than others
MILD THUNDER is offline
Old 01-26-2013 | 07:24 PM
back in the day,thats how gm use to code their engines,,454 ls 5,6,7..a letter for the hp rating..
FIXX is offline
Old 01-26-2013 | 08:02 PM
fix
any idea what this would be
cig20 is offline
Old 01-26-2013 | 09:36 PM
Default fixx
fix
ok ,,when you hear the term number's matching when buying a numbers matching car thease are the numbers you need to look at..those numbers and letters tall you where the engine was casted,what date and type of vehicle it belongs in..their called suffix engine codes..you can try google.. try chevy 454 engine suffix codes..
FIXX is offline
Old 01-28-2013 | 02:10 AM
5 xk
5=GM s model year. In this case it could be 1995 1985 or 1975.
GM Engine Codes
The model of MerCruiser engine can be determined by looking at the last letters of the engine code
that is stamped into all complete long blocks. This engine code is stamped into the long block by
GM at the time of assembly.
If the engine serial number, and/or model decals are missing, the engine code will help to determine
the engine model. Refer to drawings for engine code location.
Information you need from the engine code, example V01115MD.
5=GM s model year. In this case 1995, could also be 1985 or 1975.
MD=type of engine. A 350 cid V8, MerCruiser models 5.7L Bravo, 350 Mag, 350 Mag Tournament
Ski.
Unfortunately, you're xk did not make the mercruiser list. Like fixx mentioned, Maybe googling GM's Engine Code Identification will help.
http://www.marinemechanic.com/merc/d...blockcodes.PDF
http://www.boatfix.com/merc/Bullet/95/95_05.pdf
lakematdude is offline
