Intake Manifold Help >
Old 01-27-2013 | 11:55 PM
Originally Posted by picklenjim
Talking EFI.
I don't think your going to find a manifold that will work with the rest of the Merc FI system. Is this what you have?
http://www.perfprotech.com/mercruise.../180?model=507
You could try posting in the parts wanted section on boating forums or search the net for used ones. Or you could always chang to carbs. 2K for just the manifold section is rediculous.
Yeah, Thats the correct manifold.. I know 2k is rediculous. It is the lower part of the manifold that cracked and flooded my engine. I don't want to get to deep into tunning i'd rather just have something that I can plug and play without fondling with the ECU. Where I live there really isn't anyone that can tune these motors.
intimid8 is offline
Old 01-28-2013 | 12:00 AM
Originally Posted by WAGS382
I know of 4 502 magnum MPI intake set ups, two are stock and two are ported.
The ported ones pushed a Cafe Racer into the low 70's, I would guess that would take 475-500 HP.
Also have the cams and computers from the ported ones. The first thing you need on any of the BBC motors is a good exhaust.
Will the MPI manifolds fit an EFI motor? Where can I find these? Will i need to start playing around with the ECU to get it functioning correctly?
intimid8 is offline
Old 01-28-2013 | 12:02 AM
Talking EFI.
Carb isn't really an option.. Our weather gets to 120+ and I don't want to be facing all the forward-reverse-forward headaches associated with carb's
intimid8 is offline
Old 01-28-2013 | 12:12 AM
Randy Nielsen's Avatar
I have a lower intake from a 2000 502 mag I can make a good deal on. Randy
Randy Nielsen is offline
Old 01-28-2013 | 01:34 AM
I'm not positive of all the exact changes, But just so your aware, All the merc 454/502 intake part numbers (805233A6) for the EFI/MPI are the same starting in 1993 through about 1998.
502 MAG MPI BRAVO (GEN VI) GM 502 V-8 1998
Click on Serial number
0L017000 THRU 0L085432
http://www.mercruiserparts.com/Show_...+INTAKE+PLENUM
But sometime after 1998 or more importantly the engine serial number 0L085433 THRU 0M024999 had a change in intake manifold part numbers (861300A2) along with a change in fuel injector size & part numbers & fuel regulator PSI.
502 MAG. MPI BRAVO (GEN VI) GM 502 V-8
http://www.mercruiserparts.com/Show_...+Intake+Plenum
Here's the list of engines for you if needed,
http://www.mercruiserparts.com/selec....asp?type_id=8
Good luck.
lakematdude is offline
Old 01-28-2013 | 08:34 PM
Arrow
There are a couple on Ebay right now -look under Mercruiser.fuel injection. Good Luck, should not be to hard to locate some new manifold sections.
PowerRocket is offline
Old 01-28-2013 | 08:47 PM
Default MPI Intake
I have a complete upper and lower with fuel rail 500 + freight PM your email addres and I will send you pictures.
Here's the link
tunertech is offline
Old 01-30-2013 | 12:12 AM
Here's the link
Will these fit an EFI?
intimid8 is offline
Old 01-30-2013 | 01:08 AM
The manifolds everyone is replying about are EFI. Electronic Fuel Injection, The MPI means Multiport Fuel Injection. There are two styles, the older system used a lift pump that mounted on the seapump. The other style are the ones that have been pictured & uses a cool fuel electric pump mounted behind the seapump. The 500efi & 525efi are completely different. Which one do you have? Can you post some pics? I have both styles that I can sell. Randy
Old 01-30-2013 | 12:25 PM
Hey there.. I have a 502 gen v EFI. Please forgive me as I am far from being a merc guru. I know bits and pieces here and there but that's about it. I am basically looking for something i can bolt on, close the hatch, turn a key, and go!
intimid8 is offline
