more power
Old 01-28-2013 | 12:39 AM
Default more power
i have a 01 baja hammer 350 motor..would like to no how i can make it faster.it will do 63 right now stock with a 21 pitch 3 blade ss prop.single barrel carb
whiprmz is offline
Old 01-28-2013 | 12:52 AM
Randy Nielsen's Avatar
How fast do you want to go? What kind of budget? Randy
Randy Nielsen is offline
Old 01-28-2013 | 11:49 PM
i would like to get to 70 lol.prolly need to buy a new boat.was thinking of putting on a new four barrel intake and a four barrel carb.i no that wouldnt get me there but it might make it a little faster
whiprmz is offline
Old 01-29-2013 | 12:31 AM
The more info you can give about the boat & how much you can invest in it the more accurate the responses will be. A serial # for the engine & drive can tell exactly what your starting with then where to go from there. Welcome to OSO. Randy
Old 01-29-2013 | 12:33 AM
What rpm are you turning now at WOT?
What outdrive? (Bravo 1, Alpha?)
Is it a stock Merc motor?
Trash is offline
Old 01-29-2013 | 01:20 AM
Sure that's not a throttle body on an EFI system? Never heard of a single barrel carb on a 350. Don't waste your time and money on that 350. If you want to run 70 pull that engine and sell it and replace it with a 454 mag. That's what came in a lot of them and they run 70 all day. You would have to squeeze everything you could get out of that 350 and then would loose any dependability. Putting a 4 barrel intake and carb on that will do nothing but make your wallet lighter.
picklenjim is offline
Old 01-29-2013 | 02:14 AM
Buuuuuuuuuump Buuuuuuuuuump
hobdayxix0 is offline
Old 01-29-2013 | 06:11 AM
Ban
indysupra is offline
Old 01-29-2013 | 01:40 PM
Ok thx
whiprmz is offline
Old 01-29-2013 | 02:10 PM
sure that's not a throttle body on an efi system? Never heard of a single barrel carb on a 350. Don't waste your time and money on that 350. If you want to run 70 pull that engine and sell it and replace it with a 454 mag. That's what came in a lot of them and they run 70 all day. You would have to squeeze everything you could get out of that 350 and then would loose any dependability. Putting a 4 barrel intake and carb on that will do nothing but make your wallet lighter.
+1 but a cheaper way to get to 70mph... put it on your trailer and find your nearest interstate
ridefast77 is offline
