V-6 Module ?'s >
V-6 Module ?'s
V-6 Module ?'s
Old 01-31-2013 | 06:33 PM
Originally Posted by jeff32
my merc 454-420 rebuild to 485 hp were a pain at idle when engaging. my engine builder switched to V6 module... a dream come true! end of trouble! should have done that the first year, not the fifth year when I sold the boat!!!
Jeff-
Do you have any idea what size cam you used? My engines should be making the same power but as far as speed goes I'm right where guys are with 415 hp 502's. My boat came with 330's so its the only baseline I have. I know I'm a little out of my RPM's, I'm at 49-5000 and should be around 53-5400. Before I spend the $$$ to get more RPM's out of my props I want to make sure thats the issue.
endeavour32 is offline
Old 01-31-2013 | 07:17 PM
jeff32's Avatar
no idea. my engine builder did not want to give me his recipie!
jeff32 is offline
Old 02-01-2013 | 09:34 PM
Did you pay for the motor or did he give them to you? Last I checked most people wan to know what they buy. Most all good builders keep the small stuff that makes there suff better under there sleeve (chamber design,some types of porting, ect)but for the most part he should give a build sheet with the motor.
Just my 💭
2330s is offline
Old 02-03-2013 | 01:08 PM
rmbuilder's Avatar
MarineKinetics
Mike,
Move the 1.8 rocker to the intake. Is the lobe the TM***HR series, lift .340"/.578" at the valve w/ 1.7 rocker?
Bob
rmbuilder is offline
Old 02-03-2013 | 01:20 PM
Originally Posted by rmbuilder
Mike,
Bob
I wanna say it is Bob regarding the cam.
In several tests I've seen on the bbc setup, it seems the engines always responded Better to the 1.8's on the intake side, rather than the exhaust side. But that was mostly blown stuff, which one would think the exhaust side would need the help. But the dyno numbers proved the intake side worked better with the 1.8's, and showed gains.
MILD THUNDER is offline
Old 02-03-2013 | 06:36 PM
jeff32's Avatar
I paid for the engines rebuild... he rebuild me between like 1 to 10 engines a year, more expensive of the area, but never breaks ! so I said rebuild, he asked me if we would change intake, the rest of the internal needed to be all new anyways, I said go, went on dyno, did 485 hp, was happy, and was all I needed to know ! I would have forget the specs anyways... !!!
jeff32 is offline
Old 07-27-2013 | 08:37 AM
egbolt's Avatar
griff, I have a 97 donzi 22zx that we built from 454 mag a 496 stroker, eagle bottom end iron head with great flow, procharger m2sc
with 3-5 lb boost, rm builder cam. Tried best to do all the right things only want to do once!!!!
Bob has all the number and specs and said should be around 600 hp, also same comments from Kim Barr Racing engines that did the maching etc.
Couldnt get timing correct so started reading and I purchased v6-14 module + wiring harness. Question I have Thunderbolt V, module is Thunderbolt IV module. disconnected noc senser, plugged in the wht/red, wht/grn, purple to purple, grey to grey
Noi start(no Fire) is there some type of jumper wire we need to do we didnt disconnect the TB V module from wiring since we thought that is where we will get fire there are only 4 wires which I assume go to matching spots
or maybe the module/wiring I got on ebay is bad.
Are there anything special needed to be done to make work
Hope this has made sense if not please ask away
thanks
egb
egbolt is offline
Old 07-27-2013 | 10:56 AM
egbolt's Avatar
More google I think we were not grnding since we only have 4 wires it grounds from being mounted on dist. 5 wire v6-14 grounds to exhaust is that right track
egbolt is offline
Old 07-27-2013 | 11:37 PM
jeff32's Avatar
so endeavor???
did you go V-6 module? how did it go?
jeff32 is offline
Old 07-31-2013 | 07:41 PM
waybomb's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Active Streak: 90 Days
Send you email addy to waybomb at gmail. I'll send you the TBIV/TBV manual that tells you everything you ever wanted to know about them.
waybomb is offline
