fixx
Originally Posted by MILD THUNDER
(Post 3866294)
I'd be shooting for the -4 scx lower with #6 prop shafts!
This message has been deleted by mike tkach. Reason: i just dont have the heart to say it. |
Originally Posted by TunnelVision3100
(Post 3866281)
I agree with you being easier on the drives (strain wise) but one of the biggest factors for killing drives is generating heat as well. Since the 1.36 is spinning faster than the 1.5, what about the extra heat thats being made? Wont that or will that contribute to premature bearing wear?
(Post 3866255)
Actually it looks like 1.34 according to this?
http://www.mkhammer.com/imco-sc-lowe...-p-302570.html |
Originally Posted by mrfixxall
(Post 3866308)
i already mentioned that to him and a smaller diameter prop with your adaptors with the -3's...in one ear and out the other..Some people would rather have it look pirty then have it perform..me paint everything black and fine tune it and lets go boating..
I do! sorry to hurt feelings but sometimes things need to be said.. |
In all the ones that I have swapped gears in, the 1.34-1.36 does lose a little acceleration as compared to the 1.5. I only change the gears when we just flat out run out of prop. If you can run 1.5's, then I would run them.
I'm in agreement with Joe that an SCX/SCX-4 (depending on X dim.) with a #6 prop shaft would be the way to go. We have done it on a few 42's and they really seem to like it.(again, depending on X dim.) I'm in the middle of dialing one in now. It has an SCX -4 running 17 X 36 5 blades. It was a little to high, along with a few other issues. We've tried a few different spacers to get the X correct. Now that the X is where it needs to be, we are playing with props. If it ever stops raining, we may get to run it. Eddie |
Hey Eddie , you've done a lot with the 42 beakers; what have you found to be a good shaft height relative to the bottom??
Joe |
Originally Posted by Young Performance
(Post 3866446)
Eddie |
With a full stagger and #6 props, about 2" - 2.5" above the bottom seems to be the spot to be.
THe one that I have here now was quite a bit higher than that. The owner installed a -4, so it was ike 4.5" above. The boat got on plane just fine, but wouldn't carry at all. The slip was near 30%. He installed a 1" spacer with little change. I took it out with the 1" and the boat would make a SHARP right turn at 105-110 because it was unloading one of the props. Talk about scare the crap out of you. We almost got pitched out the first time it happened. I then removed the 1"spacer and installled a 2". That put it at about 2.5" above the bottom. It was a totally different boat then. I'm waiting to try another set of props with less rake. He has 18* rake props and it doesn't seem to like them. I found a set that are the same size with only 16*, so I want to try them. Eddie |
I know a lot of time the 1.36 is used to cure the "running out of prop" issue but doesn't the 1.36 also help reduce the stress on the drive and make it live longer behind bigger HP? I have a 1.36 drive behind my 22 Velocity and its not really needed but I had it and it pulls pretty good with a 24 Bravo. I still have the 1.5 drive that came on the boat and after hearing what everyone is saying I am thinking about trying it this summer with a different pitch prop to see how it affects my top speed. So far with the 1.36 drive at 5270 rpms I have run 77 GPS mph. If I can run a 1.5 drive and get the same style prop to get me to the 52-5300 rpm range will I pick up more speed? My boat gets on plane easy now with 450 hp and the 1.36 drive so planing is not a issue with the 1.36 for me.
(Post 3866537)
THe one that I have here now was quite a bit higher than that. The owner installed a -4, so it was ike 4.5" above. The boat got on plane just fine, but wouldn't carry at all. The slip was near 30%. He installed a 1" spacer with little change. I took it out with the 1" and the boat would make a SHARP right turn at 105-110 because it was unloading one of the props. Talk about scare the crap out of you. We almost got pitched out the first time it happened. I then removed the 1"spacer and installled a 2". That put it at about 2.5" above the bottom. It was a totally different boat then. I'm waiting to try another set of props with less rake. He has 18* rake props and it doesn't seem to like them. I found a set that are the same size with only 16*, so I want to try them. Eddie I don't really like the idea of going to high with the bravo style props. With a -1 lower, if the numbers he gave me are true, then his slip is good at 10% with a 4 blade bravo. Almost too good to believe. We'll see come spring. That's scary aeriating a prop at 110mph! Do you think the bullet was skating on top at that speed? :eekdrop: |
| All times are GMT -5. The time now is 12:35 PM. |
