Arias Pistons VS JE Pistons
The first thing to determine is; what are you seeing with wear, piston rocking, ring lang wear, compression ratio. Taking that you are, I guess 4.500 stroke, 6.535 rod, C.H. of 1.395. What is going on with that piston @ bottom dead center? I would question the design of skirt, ring stack and wrist pin wall thickness.
I am not going to tell you who to use, I will say: I have used CP / Carrillo, for 10 yrs now, and my engineer has corrected piston issues with other piston manufactures that I have, had come through the doors.
I wouldn't be sold on the piston coating from the manufacturer, you can address that afterwards.
Piston design, ring lang location, dish design and wrist pin size.
Good pistons look like works of art. Beautiful!
1 Post
their website show them as a in stock production piston..some builders like to pad the bill....part number 282059 if thats the correct piston..
http://www.jepistons.com/Catalogs/Au.../inv_dome.aspx
"Made to Order"
Don't ask me how I know...
Many thanks to everyone here on OSO!
Now, to find out what Bam super cyborg this 2003 hustler talon 377 has in it, needs a rebuild.
