vapor separator issues >
Old 02-14-2013 | 04:57 PM
whiskeyhangover's Avatar
Default vapor separator issues
I have a 502 EFI and when i turned the key this afternoon no
noise was heard from the VST. Any suggestions?
whiskeyhangover is offline
Old 02-14-2013 | 06:06 PM
think the motor may be bad?
Old 02-14-2013 | 08:11 PM
un plug the connector for the fuel pump going into the v.s.t and put 12 volts directly to the pump either with a power probe or jumper leads and see if the pump turns on
ballz2thewall is offline
Old 02-14-2013 | 09:35 PM
ok... i take it the black is ground? If it kicks on when i do that.... what does that
mean?
Old 02-14-2013 | 09:38 PM
when I first turn the key on today I heard it kick on... I didn't crank the motor and turned
the key back off. When i turn the key on again about 10 minutes
later..... nothing.
Old 02-14-2013 | 10:22 PM
There is a relay in the wiring harness that turns the pump on and off. If the pump is running intermittently, they you prob. have a relay going bad. Try jumping the pump directly as mentioned and see if it runs. If it does, then with the pump still unplugged, put a volt meter or test light in the power lead going to the pump and turn the key on. If it doesn't show +12v, then check the relay. You should be able to hear it clicking when the key is turned on.
Eddie
Young Performance is offline
Old 02-15-2013 | 04:31 AM
ok is the black wire the ground? It has,a black wire
and a white wire that go into the top of pump....Im just making sure
because I don't want to short anything out. thanks.
Old 02-15-2013 | 09:38 AM
yes the black wire is the ground
