-   -   Has anybody ever had Red Loctite fail? (https://www.offshoreonly.com/forums/general-q/291810-has-anybody-ever-had-red-loctite-fail.html)
Strip Poker 388 02-18-2013 11:47 PM
Has anybody have a bolt back out that has red loctite on it?
or even the Blue?
Is there anything better than the standard red?
Rob:D
toolsinbox 02-19-2013 12:30 AM
only under high heat conditions
stevesxm 02-19-2013 04:27 AM
or even the Blue?
Rob:D
what " toolsinbox" says about heat is, for sure . correct but locktite isn't what keeps the bolt tight or in place. the preload on the fastner does. locktite is the " suspenders" in a " belts and suspenders" approach. if you have harware that repeatedly loosens up or falls out its either the wrong hardware for the application or the right hardware improperly preloaded or you have components that are moving relative to each other that the clamp load is unable to control.
speicher lane 02-19-2013 06:25 AM
+1..nicely explained - I have also seen it where the threads were over chased (both male and female) with chitty dies. I guess the fellow was trying to get locktite to work as a gap filler????
TWIN-SPINS 02-19-2013 06:30 AM
monkey spit,,,has a third product
phragle 02-19-2013 07:00 AM
proper prep helps too.... how you gonna glue something oily/greasey together??
pqjack 02-19-2013 07:13 AM
+1...make sure everything is spotless...a can of brake cleaner does wonders
44MTI 02-19-2013 08:17 AM
Might also try Green Loctite
Strip Poker 388 02-19-2013 12:58 PM
If it has fuel running thru it and oil,so heat would not be a factor, I know about bolt stretch,but if red loctite was used how could a bolt back out?
Fenderjack 02-19-2013 01:04 PM
red loctite
You have to remember loctite has a shelf life if it is old it does not work.Been there done that.JOHN SR
