mockup engine >
mockup engine
mockup engine
Old 03-10-2013 | 09:10 AM
Default mockup engine
Im having glassdave redo the transom/ stringers in the scarab and also raise the x dem. Im going to need to mock up the motor mounts so i was thinking it would be easier to use a mock up block for that task. Does anyone else do it that way or is there an easier/better way?
indysupra is offline
Old 03-10-2013 | 09:15 AM
Why don't you just raise the motor mount blocks the same amount you are raising the x-dimension...I'm assuming your motors were lined up properly before the transom work when I say this.
Are yours standard screw adjustment type mounts ............or race mounts
motor is offline
Old 03-10-2013 | 09:20 AM
That was my original though but he is cutting out the stringers too.
Old 03-10-2013 | 10:31 PM
You might want to check out the plastic mock up engine blocks sold by Summit/Jegs. I would think it would make the job much easier.
snapmorgan is offline
Old 03-11-2013 | 12:46 PM
There's got to be a junk BBC laying close to Dave that can be used for mocking up. Also don't forget about standard vs tall deck for exhaust locations....
delsol is offline
Old 03-11-2013 | 01:13 PM
MER Performance's Avatar
Are you using flat pad mounts or a plate mount. Either way you will need a block, crankshaft with bearings, flywheel, coupler, bellhousing and alignment shaft. If Bravo, if trans. same process.
If using pads, add amount to stringer or some installations use a L bracket supported with gussets thru bolted and the mount bolts flat to bracket. Motor plate, well you will need L brackets 3x4-5x 3/8 with backing plates. Fabricate brackets, locate clamp to motor plate and drill stringers, bolt up, then you can locate and drill holes in L brackets.
MER Performance is offline
Old 03-11-2013 | 01:22 PM
You can't use the plastic mock up block in this situation since it doesn't have a provision for a flywheel and coupler, which you will need to align the engine. As Mark said, you need a block, crank, bearings, flywheel and coupler. You can use some old junk parts, but they must be assembled.
Eddie
Young Performance is offline
