add O2 bung in Keith Eckert aluminum headers >
Old 03-12-2013 | 07:38 AM
Default add O2 bung in Keith Eckert aluminum headers
Does anyone know if you can just drill and tap into the "collector" area of the KE aluminum headers to install an O2 sensor?
I don't have any length to install them in the tailpipe.
formulaok is offline
Old 03-12-2013 | 08:13 AM
Install the sensor as far downsteam as you can.
Jeff
sbslinde is offline
Old 03-12-2013 | 08:48 PM
blue thunder's Avatar
You should make a 1" alum spacer for between the tailpipe and header. Then at 3 oclock drill and tap the hole for the sensor. I do not believe you can do what you suggest even though there are pads that look like you could cast into the header.
blue thunder is offline
