What thread is a knock sensor?
1 Attachment(s)
Got a new Dart gen 6 block and its not drilled for the knock sensor,anybody know what size thread it is?
I'm guessing it 1/4 npt? Thanks |
Yes, it fits in the water drain hole in the side of the block.
Originally Posted by GPM
(Post 3884594)
Rob |
(Post 3884594)
Originally Posted by mike tkach
(Post 3885241)
are you saying it goes in the water drain hole,i dont think so.
on every ski boat with efi that I have worked on the knock sensor was screwed into the drain hole on the side of the block. they all came that way from the engine builders.
We put them in the drain holes on just about every engine we do. Nothing wrong with putting them there.
Eddie |
Thanks for the replies
I really dont want to put it in the drain,Every time I rebuild the engine I remove the knock sensor and the built in nut spins and rounds off, have to use channel locks it remove,maybe im screwing it in to tight,but I assume its bad after it spins. There is 2 blank boss's on the side of the block I could drill and tap,also the clutch pilot hole I could inlarge and install it there. Rob |
fixx
Originally Posted by Strip Poker 388
(Post 3885423)
3 Attachment(s)
I dont recall one under the head,I allways got it from Merc, maybe a non merc is diff? Ill look again
Rob |
| All times are GMT -5. The time now is 12:36 PM. |
