Need urgent help from an expert >
Old 03-16-2013 | 06:12 AM
Yes big spider monkey problem!
Seriously I can say there were little to no spider cracks in mine.
Unlimited jd is offline
Old 03-16-2013 | 08:14 AM
tuliping the valves a issue on small blocks with that kind of hours...as said before compression test would help ck that...
ezstriper is offline
Old 03-16-2013 | 09:30 AM
The last thing you need to worry about in that boat (or most boats) is the engine and drive. You are worrying about the strongest link in the chain. If it is fresh water 500 hrs is nothing.
Pismo10 is offline
Old 03-16-2013 | 10:36 AM
Originally Posted by Element 13
A compression test and drive check are certainly good advice.
If it were me, I would also ask the tech how much to scope the camshaft. It never lies.
Cheers
I have never heard of scoping the camshaft,can you give some inforation about that?
mike tkach is offline
Old 03-16-2013 | 10:50 AM
the deep's Avatar
Fast Singles Club
Veteran: National Guard
Wink
Originally Posted by ICDEDPPL
Also look for spider and spider monkeys in the cuddy.. its a common problem
Hillbilly terminology for stress cracks in the shape of a spider web .
the deep is offline
Old 03-16-2013 | 10:54 AM
They drill a hole through the oil pan and or the lifter valley, drop a bore scope in and take a look. It is recommended every 200 hrs
Also the OP is 5/10 on on the Darr meter, interested to see where this ends up
4bus is offline
