Trim Tab/transome sealant
I am installing a set of trim tabs. Can someone recommend a good sealant so the tabs can be removed if needed that won't damage the gelcoat?
X2 on the 3M 4200. Great stuff.
The 3M 4200 is actually an adhesive and seems to grip surfaces better from what I've seen. And if you want extra super gonzo grip, go with the 5200. Don't ever plan on getting it off though.
I use boat life from west marine. A complete circle around the fastening holes and thru-transom holes for the hydraulic lines. Then, a complete bead around the perimeter.
Install dry and tape (blue or green painters low tack tape) about 1/4" around the perimeter of the tab bracket.
Remove, apply boat life and be generous. Tighten as finished and squeeze the generous application of boat life out. Then take a 10mm socket to smooth the excess that you squeezed out onto the tape. Before dry, remove the tape by pulling away from the tab.
Water-tite, above and below the waterline.
Thanks for the input everyone!
I'm going to use the 3m 4200.
