tired of the bullsh*t vapor lock!
In the VST models, the pressure in the VST becomes higher than the pump can deliver, say 10psi in the VST vs 5-7psi max delivered. The top plug on the VST can be removed to relieve the pressure as a temp fix to get you home. I always leave mine finger tight so I can remove it.
This has been talked about a lot. If you have the VST tank, take the fuel rail return line off the vst tank and run it to your main gas tank instead. CP makes a nice piece that splices the fuel fill hose and allows you to run the return fuel line to it. Plug the fitting on the VST tank. Mine is a 96 502 mpi, and I had the same problems. I talked to the famous Eddie Young, and he suggested the above fix. Worked like a charm. Not a single issue since.
