-   -   fuel sending unit with duel return lines? (https://www.offshoreonly.com/forums/general-q/293768-fuel-sending-unit-duel-return-lines.html)
whiskeyhangover 03-30-2013 09:05 AM
Does anyone make one?
mcollinstn 03-30-2013 02:48 PM
What are you even asking?
I don't mean to sound abrupt but I don't understand your question.
A fuel sending unit has a ground lug and an output terminal (for variable resitance thru the ground) for sensing the fuel level.
Why would it have one return line, much less dual ones?
MC
lakematdude 03-30-2013 03:50 PM
Some diesel and fuel injection engines use a return line back to the tank, going through the fuel sending unit may help make some installations a bit easier.
I haven't seen a marine duel return line, just a single like this,
http://www.amazon.com/Moeller-Marine.../dp/B000MTI15U
whiskeyhangover 03-31-2013 06:50 AM
to help with the massive vapor lock problem we've been having
Everyone has been telling me to make a return back to the tank and to keep from
Drilling the tank someone told me to find a fuel sending unit with a return line.
I didn't kniw if they made one with duel return lines or not but I bet I could drill an extra one with a few fittings... .
Thanks lakematdude! I will order one
fbc25el 03-31-2013 07:57 AM
CP has a fitting where you can cut your fill hose to your tank and install your return lines.
