Mercruiser engine questions >
Old 04-30-2013 | 11:43 AM
Probably best to grab some serial numbers so you can know for sure.
Captain YARRR is offline
Old 04-30-2013 | 12:55 PM
Originally Posted by mcollinstn
Gil manifolds DO help.
They probably are good for 10hp on a 454 Mag, and maybe 12-14hp on a 502Mag.
That puts your 454 Mags at maybe 375 instead of 365, but it technically doesn't change the ENGINE RATING.
Not sure where you're getting the 40hp difference, though unless you're counting the drop from crank rating to prop rating.
It's really irrelevant if you plan to add hop up goodies. Once you change the cam, do some port cleanup on the heads, bore notch the cylinders, and zero deck the block you're going to be well over 400-430hp. You have a good motor to start with.
Just be glad it's not the 330 version, which has weaker bottom end and poor flowing heads.
i have twins so thats why i said 40hp
soldier4402 is offline
Old 04-30-2013 | 12:57 PM
I have them, also going to do a double take of the fountain build and inspection sheet I have when I get home.
Like I said do a nada guide run on a 91 fountain fever and it shows 385hp. I guess if the Gill added 10 hp, its possible 10hp might have came from somewhere else.
Old 04-30-2013 | 06:00 PM
350hp prop according to the Mercruiser brochure I have in my hand.
Pismo10 is offline
Old 05-01-2013 | 08:26 AM
http://www.boatfix.com/merc/Bullet/91/91_16.pdf
Case Closed! This is straight from Mercruiser. Prop HP is 350 on 454 mag/bravo
92nsx is offline
Old 05-01-2013 | 08:35 AM
Ok i looked last night at the performance sheet the day the boat was ran, actually had a time, date, and test drive Actually had Reggies signature there, for those making jokes. It did say 365hp for each engine, so the case is now closed. But I find it funny how Nada, insurance keeps saying their 385s.
Old 05-01-2013 | 08:40 AM
It all depends on the year, the 454 mag was 385 later.
Pismo10 is offline
Old 05-01-2013 | 07:55 PM
I doubt the data entry geeks for the NADA database are mercury engine experts. I have noticed other errors on the NADA website and unfortunately this is the information that the insurance companies have to work with
dandercam1 is offline
Old 05-01-2013 | 08:07 PM
yeah i doubt their pricing as it is. If i check my 91 it says 17k for the thing, and I dont think you could fine a running fountain for under 20
Old 05-02-2013 | 05:06 PM
Hahaha agreed. Now this topic sounds like it could be the start of an interesting thread.
