Front Cylinders not Firing >
Old 04-29-2013 | 02:21 AM
Cracked weld in the header that opens up as it gets warmer?
Alex is offline
Old 04-29-2013 | 11:03 AM
I water pressure tested the header and it seemed to be ok. Could a cracked weld be closed that tight when cold to hold pressure of a garden hose on full blast?
Seahawk 2000 is offline
Old 04-30-2013 | 11:50 AM
ttt
Old 04-30-2013 | 12:53 PM
Rookie's Avatar
Heat will expand the crack. I would fix the water issue before I would even start worrying about the front cylinders firing. You can cause some sever damage and front cylinders not firing will be the least of your worries. The water is probably the root of your problems.
Also the garden hose won't keep up with the volume of the sea pump.
Rookie is offline
Old 04-30-2013 | 02:44 PM
I think the water is putting out the spark plugs close to the crack. I guess I'll swap the header from the good motor and if that doesen't fix it I'll bet it's a cracked head.
Old 04-30-2013 | 03:13 PM
Rookie's Avatar
That would suck. I just don't want to see you fill up a cylinder and then bend a connecting rod.
Good luck
Rookie is offline
