So how many batteries can you safely charge?? >
Old 05-07-2013 | 04:41 PM
Originally Posted by CC230
I run 2 house batteries, and 1 engine battery. I turn the Perko switch to house while sitting and put it on both when I fire it up to leave. I put it on both because they say never switch the Perko switch while running.
Most Perko can be switched between 1, both, 2 while running; just don't over shoot/turn the wrong direcction to Off.
If you have a 3 wire alt there is a more expensive model with a field disconnect that can minimize the chance of damage but it is best to not go there regardless.
The way Perko sets up their order: off, 1, all, 2; overshooting is very unlikely as 1 is usually the start battery so as long as you turn the correct direction to charge while leaving, you will be fine.
Check you model number before making this ASSUMPTION.
ChargeIt is offline
