Distributor not dropping down >
Old 05-07-2013 | 06:21 AM
you stripped out dist gear last summer. this cam or diff cam? try a different dist. take off chain and slip cam forward. does dist drop? stick another manifold on. see if cam sits on it ok. there is a lot of ways to check stuff before getting something machined...
dereknkathy is offline
Old 05-07-2013 | 03:37 PM
check rear cam expansion plug,if installed too deep it may be forcing the cam forward too much..
FIXX is offline
Old 05-07-2013 | 06:18 PM
Thanks for all the input so far guys. Here is what I have found out today. It appears that the intake has been milled at some point. There is about an 1/8 of an inch difference between a 330 that I have and this one, measuring from the top of the block to the top of the collar on the intake. When I drop the distributor in, I can see that it hitting the step inside the block under the cam gear. There is nothing I can do to get it to drop down father. I'm guessing I just need to shim the distributor to the proper height unless someone has another idea.
endeavour32 is offline
Old 05-07-2013 | 06:33 PM
Get a distributor with an adjustable locking collar.
Nmbr1GMfan is offline
Old 05-07-2013 | 06:42 PM
If everyone thinks shimming is a bad idea I'd rather just buy a new intake. I really don't want to go through the hassles of replacing two distributors as I'm running twins. The stock Thunderbolt set up is just fine for my engines.
Old 05-07-2013 | 07:04 PM
If the shim is one that will allow the dist. to stay centered and supported and its properly in the oil pump drive you will be fine.
Old 05-07-2013 | 08:38 PM
Rookie's Avatar
What intake gaskets are you using? Don't they make thicker gaskets to make up for that.
Rookie is online now
Old 05-07-2013 | 08:51 PM
They are Mr Gasket Ultra seal gaskets... I don't think they make them an 1/8" thick, I'll take a look though, maybe they do.
Old 05-07-2013 | 09:00 PM
What a joke! I just looked up the receipt they are Mr Gasket 5818 they are the thickest gasket you can buy .125. I wish I could remember who I bought these intakes from. I asked if they were milled and of course I was told no. This intake has had the **** milled out of it.... What stinks is I know it was an active member that I trusted on here.
Old 05-07-2013 | 09:07 PM
blkhorse's Avatar
you sure the intake is the issue? hate to see someone trashed for assumptions. JMHO. maybe totaly off base, if so...sorry
blkhorse is offline
