-   -   Broken 454, options? (https://www.offshoreonly.com/forums/general-q/295970-broken-454-options.html)
Nmbr1GMfan 05-07-2013 06:59 PM
A scuffed piston in a .030 over 454 led to some knocking so I guess Im due for a rebuild. Currently has 088 rectangle heads and an unknown hyd flat tappet cam. Dual plane alum manifold, Q-jet and stainless marine exh. I'm thinking of building a 496 with this cam. What do you guys think?
http://i537.photobucket.com/albums/f...ps8f75b94a.jpg
KEPP 05-08-2013 08:58 AM
Just be careful and make sure you have an exhaust system that won't present reversion problems for you. I'm sure the cam will make fine power as if you ask ten different people you might get ten different answers. But your durations up in the 240's at .050 will definitely wreak havoc with many brands of manifold systems with short risers. Best regards
Nmbr1GMfan 05-08-2013 02:45 PM
Here is the exhaust, will it be problematic?
http://i537.photobucket.com/albums/f...ps82785163.jpg
Budman II 05-08-2013 08:56 PM
Rectangle port heads, cam with 240* @ .050, nearly .600 lift, and 110* LSA, and they are running what appears to be a stock Merc intake and a Q-jet? Just seems to be a lot of cam and heads for 750 cfm - unless the carb has been reworked considerably.
You will find that most of the pro engine builders on this forum recommend a hyd roller over a flat tappet, especially with that kind of lift. Yes, it's more expensive, but it will also run for the long haul if set up properly. Don't skimp on the valvetrain on a marine engine - buy the best springs, pushrods and lifters you can afford.
Looks like Stainless Marine exhaust with long risers. Should be able to run a cam with pretty good overlap with those. Still, they can develop leaks. I would wait for the tear down to see what happened - that could affect the direction you take going forward.
I have been told by people who should know their stuff that the longer stroke of a 496 could make an engine more prone to reversion. The piston is developing more speed on the downward stroke, so it tends to pull the intake and exhaust pulses back into the cylinder more easily.
If you are on a limited budget, stay with the 4 inch stroke and concentrate on good heads and valvetrain. I learned the hard way - now I'm doing it for the second time in three years.
US1 Fountain 05-08-2013 09:05 PM
Does that exhaust just have an outter tube welded onto the risers, without actually changing the point where water and gases mix? Looks like a owner modification to risors that are originally for silent choice.
1BIGJIM 05-08-2013 09:08 PM
I have built several 496 strokers with great success.
Save yourself the headaches, have RMBUILDER Bob Mandra grind a custom roller for you, and your needs. You will not have to worry about reversion etc. Roller cam is the only way to go.
A longer stroke has nothing to do with reversion. It caused by exhaust pulses. Ask Bob when you talk to him, he will explain it in simpler terms.
mike tkach 05-08-2013 09:21 PM
i agree,call bob,im pretty sure he is going to say that cam with that exhaust system is going to create some reversion.
f_inscreenname 05-08-2013 10:43 PM
Here is what I did and I talked to Bob also and I use Mercruiser 496 aluminum exhaust.
*1987, MIE/340 (7.4) 454 4 bolt main Big Block
Dip it and hone the decks and cylinders cut .060 over
Block was detailed with all casting debris removed
*Scat 9000 Crank 4.25, 496 stroker
*Scat 26385P - 6.385 in. Connecting Rods - Bushed -I Beam Forged 4340 steel
Howards Cams 120255 - Max Torque Retrofit Hydraulic Roller Camshafts, Hydraulic Roller Tappet, Advertised Duration 288/294, Lift .585/.610, 112 L/S
Howards Matching Valve Springs 98636 - 130# / 330#
Cloyes Gear 9-203 - Cloyes Wear Plate, 031 in. Thick,
Maxspeeding Hydraulic Retrofit Roller Lifters
*Probe 496 Dome Top +18.0cc - SRS Piston Set
Clevite 77 Cam Bearings
Federal-Mogal 4400 M20 Main Bearings
King Engine Rod Bearings CR849HP
Cloyes true double roller timing chain
Mahle - Plasma Moly Coated piston rings
Melling 10778C (Anti-Cavitation) oil pump
Melling HV oil pump shaft.
New Harmonic Balancer
Rotating Assembly Fully Balanced
Comp Cams High-Tech pushrods #7954
Completely refreshed Chevy Heads 14096188 / 454 Open / 118cc / 3angle valve
APR head bolt sets
ARP 1.90 rocker studs
Norris S/S 1.7 roller rockers
Seal Power Gasket set
EDELBROCK BBC R2 AIRGAP INTAKE
Pro Comp 2752 Fuel Pump
MSD Ignition
Pro Comp distributor
Super Stock coil
8mm Accel Hi performance wires
New single wire alternator
Mini (gear reduction and fully marine) starter
Edelbrock 800 carburetor
12" aluminum, oval air cleaner (with K&N filter)
Brass freeze plugs
Stainless steel bolt set
4” Stainless steel "tall" risers
496 MerCruiser exhaust manifolds
Sherwood motor mounted raw water pump
Gun Slinger 05-09-2013 12:19 AM
Just out of curiosity, aren't those risers long enough to not have to worry about reversion?
Nmbr1GMfan 05-09-2013 04:32 PM
No, its currently an un-known hyd flat tappet with 088 heads a dual plane and Qjet. The 496 will have the 088s and the cam listed on the card which is a hyd roller.
Budman II 05-09-2013 10:01 PM
A cam with that much duration and overlap would work better with a true header. And like US1 Fountain said, make sure the water is being introduced way down stream. There have been a lot of people on here who have still had reversion issues even with tips that dump water all the way back at the transom.
Personally, I think with a 496 you could still make excellent power with less duration and a LSA around 112, but dial in more lift. A good hyd roller with quality lifters (like the Morels) can handle the lift and fast valve action, but you need good springs and pushrods as well.
Like others have said, Bob Madera at Marine Kinetics would be a good person to talk to about your setup. He is a wealth of information and very easy to talk to. Give him a call at 585-654-8583. He will put you on the right path. Also, there was an OSO member named ThunderStuck who had one of Bob's Gen VI step nosed cams that would be ideal for a 496.
Nmbr1GMfan 05-14-2013 02:58 PM
Thanks for the info guys, the engine is going to an engine builder so I won't burn it up again.
