idle is up at 2000 help >
Old 05-10-2013 | 09:12 PM
Have you checked the base timing as suggested?
cloudmaster_321 is offline
Old 05-10-2013 | 11:57 PM
Have you checked all the bolts and gaskets on the intake? They have to be REALLY cranked down (no rips whatsoever in the gaskets). I dont know the torque specs but if they arent tightened to spec you will have vacuum leaks which will cause the idle to skyrocket.
Powerquest_Baby!! is offline
Old 05-11-2013 | 06:50 AM
Originally Posted by osure
Alright checked for leaks can't find any vacuum is 12-15 surge was better after I reset iac but still idles at 1200 then when you give it throttle it holds at 2000. Throttle positioning sensor?
How many more parts are you gonna guess and throw at it before you check the basics?
You can also purchase complet scanning software for a pc, mefiburn.com. $199 for your computer
4bus is offline
Old 05-11-2013 | 02:31 PM
I agree I need to get a scanner 199 is a great price on it. I am trying to ck everything I can bolts all tight looked for any vac leak but don't see one. May have to leave it alone till I get the scanner
osure is offline
Old 05-11-2013 | 03:49 PM
Or...jump pin a to b and check the base timing at 1800
4bus is offline
Old 05-11-2013 | 10:47 PM
BUP
I think it was said that the throttle plate was closed - double check that to make sure its closing all the way at idle. Also I would have the motor scanned and especially take a look at the TPS = throttle position sensor.
BUP is offline
Old 05-11-2013 | 11:39 PM
If your worried about an intake leak, when its idling at 2000 rpm squirt some wd-40 or water along the intake/head junction and see if it sucks it in and if idle drops. Not fool proof, could have gasket leak on bottom of manifold.
TahoeRick is offline
Old 05-12-2013 | 08:42 AM
Think I have ruled out vacum leak as I put handle of screwdriver over iac and it idled right down to 600 rpms and I could give it gas goes up fine and comes right down. So I am thinking if it was a leak I would not be able to make it idle down. So the iac is making it idle up. I checked the tp yesterday reads good. Am going to try pin a and b but not sure it will work as motor is 2001 and think I read that trick is for older motor but if it does I will ck timing
osure is offline
Old 05-12-2013 | 08:58 AM
Pin A-B works on all MEFI controllers, which your engine has. My engines are newer and that is how I set the timing. After that an analog timing light will tell you where you are timing wise.
4bus is offline
Old 05-12-2013 | 09:56 AM
Got it will check
osure is offline
