Water pressure..draw off location? >
Old 05-09-2013 | 06:20 PM
Default Water pressure..pick up location?
I am installing a water pressure gauge on my new motor, need advice on pick up location.
My new setup is a 502 with a closed cooling system. I want to monitor water pressure from my sea pump to my closed cooling heat exchanger to make sure I have sufficient flow. With my recent gauge purchase I also got the tubing kit and a 1 1/4 s.s. splice fitting with a female 1/2npt fitting so I could adapt down to the pressure gauge tube fitting.
My plan was to splice into one of the hoses before the raw water entered the heat exchanger. Would I be better off splicing in before or after the oil cooler?
Or is there a better way to do this all together?
Derek.
bajaboy217 is offline
Old 05-09-2013 | 06:23 PM
Randy Nielsen's Avatar
The engines I put in my Kackina have the pressure dumps just off of the sea pump before the oil cooler. Randy
Randy Nielsen is offline
Old 05-09-2013 | 06:35 PM
What should the psi be after the sea pump? Where it's not going through the motor is it necessary to bleed off excess pressure?
Old 05-09-2013 | 08:10 PM
I'm thinking 18-20psi @ wot. I have read that too much pressure can cause gasket problems. I am pretty sure that is where Bob @ Bullet engines told me to set it. At idle the pressure will be low like 0-3psi. Randy
Old 05-10-2013 | 12:29 AM
I put mine in the intake manifold per my engine builders recomondation. There are many opinions on where to locate the pressure relief valve.
Revd Up is offline
Old 05-10-2013 | 05:26 AM
the op asked where to take his pressure reading from,and i don,t think it matters if before or after the oil cooler,the pressure will be the same.on a closed cooling system you do not want to dump any water from the closed side.
mike tkach is offline
Old 05-10-2013 | 05:53 AM
mine is in the intake manifold. i see maybe 2-3 psi at idle and around low 20's hammer down.
gsxr1216 is offline
Old 05-10-2013 | 06:08 AM
Thanks guys.
It looks like my post was a little misunderstood.
Mike T, has it though.
Not looking to dump water.....looking to find a pick up location (closed cooling.)
Old 05-10-2013 | 06:37 AM
I'm sorry, I saw the 1 1/4 splice fitting & went with it. If you have a 496 I would mount it as close to the exchanger inlet fitting as possible. The reason for this is because I had a problem with one of mine running hot & I finally backflushed it from that point to clean the coolers. If I had a gauge to monitor I might have caught it sooner with less head scratching. Nice catch Mike I was beginning to act like I knew something for a minute. Randy
Old 05-10-2013 | 07:03 AM
Randy, sorry for the confusion. Your proposed location of the pick up makes perfect sense.
Derek.
