quadrajet idle tuning question >
Old 07-27-2002 | 10:54 AM
Default quadrajet idle tuning question
Boat is loading up at idle in no wake zones and wants to stall and transom gets dirty quick, what should I work on first, primary jets or enrichment screws on the front of the carb? I increased the primary jet size by one when rebuilding the carb for the increased hp motor. Motor went from 454/365 to 454/450ish. Thanks for any help.
BGIII is offline
Old 07-27-2002 | 11:02 AM
dyno's Avatar
Charter Member #655
Dave will be around sunday....he went to Oshkosh, He can fix you up!
If your boat has a sail do you ride a horse to the ramp?
dyno is offline
Old 07-27-2002 | 12:07 PM
Ted G's Avatar
You should be able to clean it up with the screws. If not check to see if float level is correct. Also if you have any long crank problems you may have the core plugs at the bottom of the bowl leaking.
www.cbpba.com
Ted G is offline
Old 07-27-2002 | 02:00 PM
Thanks Ted, no problems w/ long crank, just starts sputtering when in no wake zones and seems a little flat taking off. Wanted to start out a little on the fat side and it looks like I am.
BGIII is offline
Old 07-27-2002 | 11:30 PM
John B's Avatar
Did you gain 85 horsepower by changing the jets only? It should be that easy.
Seriously, Try the idle air screws @ between one and two turns out.
JB
John B is offline
Old 07-28-2002 | 12:57 PM
Crazyhorse's Avatar
It's time to buy that 38 Top Gun you've been dreaming about. First off, we need to verify the timing before making any changes. Give me a call at your convenience. And yes, the Oshkosh airshow was awesome. The Korean War-vintage F-86's really beat up the airfield.
Crazyhorse is offline
Old 07-28-2002 | 03:56 PM
Floats in the quadrajets are always going bad. They want to sink. Check it out.
Gearhead99 is offline
tmthunder
6
05-01-2007 05:14 PM
Fountain38
0
07-05-2005 07:25 PM
jwbbuck
10
06-15-2005 01:56 PM
formula31
19
04-02-2003 01:18 PM
BGIII
1
09-18-2002 10:28 PM
