-   -   MSD Blaster Coil - Ballast Resistor? (https://www.offshoreonly.com/forums/general-q/29714-msd-blaster-coil-ballast-resistor.html)
olysan 07-28-2002 07:49 AM
Do I need to add a ballast resistor when using an MSD coil with my tbolt IV ignition. The coil info says to add it if using a "stock points" style ignition. I'm not sure if that includes the tbolt IV or not.
Mike
Shooter 07-28-2002 10:09 AM
I have a IV with MSD (for the blower) and I don't use it.
Team Gary 07-28-2002 11:32 AM
No, you don't need a ballast resistor. Your Merc ignition is HEI. Which means it dosn't have points. I don't know why you would want to use MSD? You would be better off with a V-6 moduel. MSD is very over rated.
stevejohns 07-28-2002 11:58 AM
T gary , what does the v6 module do? I think he was just replacing the coil , the merc one runs 18,000 volts and the msd one 40,000. I did the same thing to mine. sh
Team Gary 07-28-2002 12:29 PM
A V-6 moduel only has 14 deg of advance. So if you set your total timing at 32, you have 18 initial. It will start just fine, and You will notice better throttle response. Chevys seem to like more initial timing.
stevejohns 07-28-2002 06:36 PM
Do you have a part # and a ruff cost? thanks sj
Shooter 07-28-2002 07:39 PM
I have a TBolt IV with a blaster cpil and the MSD 6AL with rev limiter built in. Setup runs fine. Good idle, no transome soot. Can't tell anymore power but certinaly runs smooth.
olysan 07-28-2002 09:04 PM
Thanks for the responses. That's what I thought, but I wanted to hear it from the experts.
Team Gary 07-29-2002 10:32 AM
Stevejohns, The moduels come in two different styles. One bolts to the exhaust riser, the other one piggybacks to the distributor. I would need to know which one you want befor I can get you a part #.
stevejohns 07-29-2002 11:26 AM
TG.. mine is the one that sits against the riser. Thanks sj
