motor knocking after tune up >
Old 05-30-2013 | 08:57 PM
Default motor knocking after tune up
I have a gen V 502. Over the winter I had my starboard motor rebuilt and the port motor tuned up with new plugs, rotor, cap and plug wires. Port Motor now has a loud knock to it. Any ideas? Thanks
sanderps is offline
Old 05-30-2013 | 09:16 PM
crossed plug wires.. go over the firing order..
FIXX is offline
Old 05-31-2013 | 10:00 PM
Checked plug wires, they are correct. I did find water oil mix on inside of valve covers, but not on dip stick.
sanderps is offline
Old 06-01-2013 | 09:22 AM
rotor not pushed down all the way?
boatnt is offline
Old 06-01-2013 | 11:42 AM
you did use a mr43t plug rite??? make sure you did not use a ts plug,,it has a extended tip..then their are longer plugs that will screw in and hit the piston..
FIXX is offline
Old 06-02-2013 | 12:43 AM
I will have to check. I had a marine shop do the tune up while my other motor was getting rebuilt,
sanderps is offline
