Engine bogging after jumping waves >
Old 06-13-2013 | 08:29 AM
Originally Posted by Mbam
Holley also makse an offroad needle/seat
https://www.holley.com/6-513.asp
If you have the stock Weber carb Eldebrock makes one that you can use also. It's spring loaded. Great for boating in the air.
NightHawk is offline
Old 06-13-2013 | 09:30 AM
Umm just a little FYI you will never get a Holley to work right with a 45 degree angle. The front bowl will fill up then when your back level it only has one place to go, the engine. I would be more worried about braking the boat in half then a carb trouble. Fuel injection as mentioned is the only way u can get away with that much angle.....
So2fast5u is offline
Old 06-13-2013 | 08:02 PM
Thanks for help guys ill play with float level
pantera232 is offline
