What boat is this? >
What boat is this?
What boat is this?
Old 06-19-2013 | 10:14 AM
Velocity Vector's Avatar
Crazy Energy
Not much more than we already knew no model
The Boat History Report for this 1988 Chris-Craft is available.
HIN:
CCBA6121I788
Watercraft:
1988 Chris-Craft
Not your manufacturer? Click here.
HIN Search Results:
1 Records found in the database.
What is a record?
Important: When you are spending thousands on a used boat, you can reduce your risk of buying a boat with costly hidden problems by learning more about its history.
Velocity Vector is offline
Old 06-19-2013 | 01:01 PM
All three engines fired right up no problems no misfire, so then this is a bad hull to buy?
kakarot is offline
Old 06-21-2013 | 09:10 PM
first question is what are the engines, trailer, etc worth? if they add up to enough that the hull is basically free then it could be a deal. so long as the hull is solid and you are not worried that it truely is a Chris Craft then I would say look at it as a possible good deal.
compedgemarine is offline
Old 06-21-2013 | 09:53 PM
Looks like a Carrera 36 , does not look like a chris craft..
Here is pic of newer CARRERA 36 with rounded back,older models had a squared off back:
http://sacsmarine.com/wp-content/upl...104652_4_0.jpg
HTRDLNCN is offline
Old 06-22-2013 | 09:09 AM
All three engines are about 20-23K total trailer 2-3 hull 8-10 it's a fair deal but what concerns me
Is the hull it's an identical copy of the old inboard Carrera nothing to with Chris craft
kakarot is offline
Old 06-22-2013 | 09:16 AM
if you look here its the same hull....
http://www.offshoreonly.com/forums/s...36ft-hull.html
kakarot is offline
