Exhaust / cam question >
Old 06-13-2013 | 12:58 PM
Default Exhaust / cam question
If you are running hardin marine headers. From what I can tell basically a dry exhaust system until it dumps out the tube flush with the exhaust pipe. Also the exhaust being above the rub rail is reversion still an issue when having a cam ground.
Lake Pirate1 is offline
Old 06-13-2013 | 01:01 PM
I would say reversion wouldnt be a problem as long as the water is dumping further away from the riser elbow!!
fleg1 is offline
Old 06-13-2013 | 05:47 PM
should be ok
ballz2thewall is offline
