525's Running Hot >
525's Running Hot
525's Running Hot
Old 06-16-2013 | 02:41 PM
Default 525's Running Hot
Have a 2004 35 Fountain with 525's port motor is running way hot 195. Changed sea pump impeller and back flushed still running hot. Any thoughts on where to look next?
39 Unlimited is offline
Old 06-16-2013 | 03:13 PM
I had an issue once where a tiny rock made it's way to the thermostat and stuck it. Worth a look maybe.
POWERPLAY J is offline
Old 06-16-2013 | 08:22 PM
I had similar issue with a 502EFI closed cooling system. Took the end caps off the heat exchanger and found some gunk, cleared out the passages with a thin metal rod. All was good after that.
Got Cigs is offline
Old 06-16-2013 | 10:44 PM
VoodooRob's Avatar
Go thru your heat exchanger and sea strainers.
VoodooRob is offline
