MSD ready to run distributrs? good or bad??? >
Old 06-18-2013 | 03:32 PM
I would run a H/P HEI before using one of these, can get a decent one, complete w/coil cap etc, then get a vac advance block off and the 2 connectors and all for about $100 used many of them and work great...
ezstriper is offline
Old 06-18-2013 | 04:32 PM
articfriends's Avatar
Originally Posted by Mike S.
Will one of these work on a 502 mpi mag without any issues just install wire and go r will in interfere with the computer sys? Anyone do this?
No, your 2 plug coil/distributor ignition system tells the ecu when to fire your efi and the ecu determines the timing curve, cannot simply drop in a "old" style msd distributor in your case, Smitty
articfriends is offline
Old 06-18-2013 | 05:44 PM
Full Force's Avatar
I hate the HEI look... and the marine ones I see are around 200.00 I am looking into a few things...don't want to see the vac advance diaphragm either...
Full Force is offline
Old 06-19-2013 | 10:37 AM
These are what I ran on my stock 420's in my old Excalibur. I do believe the advance curve is fully tailorable to different needs. Stock they come with 24* of mechanical advance. The curve and total advance may be modified though.
http://www.summitracing.com/parts/ma...make/chevrolet
http://www.summitracing.com/parts/ma...a/instructions
MILD THUNDER is offline
Old 06-19-2013 | 10:47 AM
Full Force's Avatar
Do you still need ignition box? Or are these self contained?
Old 06-19-2013 | 10:50 AM
From the link.
Computer-Controlled Compatible:No
Trigger Style:Magnetic
Advance Type:Mechanical
Cap Style:Female/Socket
Mechanical Tach Drive:No
Slip Collar:No
Gear Material:Steel
Ignition Box Required:No
Distributor Gear Rotation:Standard
Distributor Cap Color:Blue
Housing Material:Billet aluminum
Housing Finish:Natural
Marine Use:Yes
Quantity:Sold individually.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
Replace your OE distributor with one of these modern, high performance marine magnetic breakerless distributors from Mallory. Their complete, self-contained ignition system combines the triggering device and amplifier into a single unit that sits inside the distributor housing. The self-contained module/pickup assembly has no moving parts to wear out, making them superior to many other designs. Their time-tested breakerless ignition circuit and surface-mounted, Thermal-Clad construction provide reliability in harsh marine environments. Designed for 12 V negative-ground systems, they improve combustion efficiency and spark plug life, provide accurate timing, and have a simple wiring hookup for easy installation. They're designed to work with both OE and aftermarket coils, so you're sure to find the combination you need.
Old 06-19-2013 | 10:52 AM
Full Force's Avatar
Oh duh missed that
Old 06-19-2013 | 11:11 AM
I have heard that you can run a msd pro billet dist without the ignition box and just use a gm hei module in place of the box. Does anybody have info. on this?
fbc25el is offline
