Exhaust leak >
Exhaust leak
Exhaust leak
Old 06-24-2013 | 04:18 PM
Default Exhaust leak
My boat has developed an exhaust leak & the RPMs are down. I tightened the manifolds which help but now the leak is back again so I’ll replace the gaskets. Just wonder if the exhaust leak would cause a significant rpm drop (500 rpms) also or should I be looking @ 2 separate problems.
Itsallgood995 is offline
Old 06-24-2013 | 04:24 PM
i dont think an exhaust leak will cause the engine to loose power,sounds like something else is wrong.
mike tkach is offline
Old 06-24-2013 | 05:47 PM
dont over look this,if its down on power or it could be runnig lein and could be causing more heat out the exhaust which will cause the bolts to stretch a bit to cause the leak in the first place..
FIXX is offline
Old 06-25-2013 | 12:14 AM
An exhaust leak won't cause a 500 rpm loss in power. I think you've got another issue. Probably too hot/lean and burned the exhaust gasket.
Griff is offline
Old 06-27-2013 | 10:32 AM
Thanks for the tip. If anything it seems to be rich with the sooty transom & plugs. Plug # 5 was lean which is where the exhaust leak was. I’m guessing the exhaust leak cause the lean plug? I’m going to do a compression check on that cylinder as well.
Old 07-02-2013 | 12:19 PM
Still haven’t checked the compression but did notice the cap & rotor had a lot of build up which I cleaned. I’m hoping that is the cause of the rpm drop. I have the TBV & noticed the terminals are aluminum. Is there a brass terminal cap & rotor for the TBV or are they all aluminum.
Old 07-02-2013 | 04:45 PM
Is it an EFI motor? If so that injector might be slightly clogged and would cause a lean condition.
Trash is offline
Old 07-02-2013 | 05:14 PM
Its carbed. When I replaced the gaskets I switched the plug & that cylinder was still lean after my next run. Think I found the RPM drop with the fouled cap & rotor but won't know till this weekend.
Old 07-31-2013 | 05:21 PM
No PSI in # 7. Pulled the head & the intake valve is warped has a sucked in look to it. The motor did get hot @ the end of last season with a worn impeller . I'll clean the carb while everything is down as well. Would this be considered a burnt valve? I always thought burnt valves were exhaust valves?
Old 08-01-2013 | 07:40 AM
Might as well pull both heads and do a top end on your engine now Your half way there already.
As so burnt valve or a warped one, well I would imagine it had to get real hot to warp....
92nsx is offline
