496 stroker jetting questions
Have a 496 stroker getting finished in the machine shop right now after oil pump went on the first run of the season, dropping it in my baja hammer. Got a new Holley 750 and was looking for any info on jetting. Not that I'm not experienced with minor jetting, I'm more looking to see if the jetting is close for the first run or if anyone else has this set up n can give me a starting point. Also has Gil exhaust and edlebrock intake Mallory ignition. Current jetting is:
72 main jets 31 main squirt 80 secondary jet 28 secondary squirt Any info is appreciated. Thanks! |
i see you are a new member,welcome aboard,that jetting seems lean for a 496,i would start with 80 in front with a power valve and 90 in the rear with no power valve,better to be rich than lean on a marine engine.
Originally Posted by mike tkach
(Post 3951083)
