Port engine still weak, advice needed. 2005 496 ho's >
Old 07-03-2013 | 10:37 AM
Default Port engine still weak, advice needed. 2005 496 ho's
My port side engine is strong until approx 2900 rpms, will only run faster with the starboard engine accelerating to bring it up. it is good & strong up to that point. Rinda scanner show no faults & the ecm shows 100% power available. Did the induced misfire test to all cylinders & all are firing, swapped out fuel filters & then the whole cool fuel/water seperator modules. Put a fuel press gauge on the injector manifold & it shows a rock steady 44 psi the whole time, even at 2900 rpm's when it stops accelerating. checked the throttle cable & linkages to verify full movement.
Not sure where to go next, thinking about swapping ecm's. Any advice is appreciated
JETDOC is offline
Old 07-03-2013 | 10:42 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Have you done a compression check and leakdown test?
Any noise in the valvetrain?
Sydwayz is offline
Old 07-03-2013 | 11:00 AM
No abnormal noises, havent done a compression test. I figured there would be an oil consumption issue or some smoke & a throttle split if that was the case.
JETDOC is offline
Old 07-03-2013 | 11:25 AM
lastcall02's Avatar
Make sure you do not have a fouled spark plug(s). Might be a good idea to change all your plugs if it's been awhile.
lastcall02 is offline
Old 07-03-2013 | 04:54 PM
all the above..if all checks out suspect the injectors are plugged..send them out and have them cleaned and checked
FIXX is offline
Old 07-04-2013 | 02:52 AM
metazcq is offline
