-   -   Flywheel On 496 Stroker (https://www.offshoreonly.com/forums/general-q/299363-flywheel-496-stroker.html)
Craney 07-07-2013 01:45 PM
Can I use my old flywheel and harmonic balancer from my old motors, they are gen.4 motors with 2 piece rear main seal? The stroker kits are internally balanced I think.
motor 07-07-2013 02:37 PM
If your gen iv's are 454's you will need new flywheels ...454'a are externally balanced...Same with balancer
ezstriper 07-07-2013 03:27 PM
need 396-427 type...and you better get the engines balanced !
Craney 07-10-2013 05:38 PM
The stroker kits are internally balanced.
FIXX 07-10-2013 07:51 PM
6.385 rods and forged crank?? dont buy the assy ballanced,,the machine shop will have to check it again and they can machine the weight off the flywheels and like mentioned you will need a 396-427 harmonic lancer..
Craney 07-10-2013 08:48 PM
Yes the rods are 6.385 and the crank is a 4340 crank.
