Broke starter and ring gear >
Old 07-09-2013 | 03:38 PM
johnnyboatman's Avatar
Default Broke starter and ring gear
Do i have to pull the drive again or can i slide it far enough forward and get it off the splines to lift the engine high enough to change the ring gear. Ive put 1.45hours on it in two seasons kind of getting tired of working on it.
johnnyboatman is offline
Old 07-09-2013 | 04:43 PM
yes you need to pull the drive to remove the engine to remove the flywheel to replace the ring gear..
FIXX is offline
Old 07-09-2013 | 05:01 PM
Viperfitness1's Avatar
try this... tap your heals three times and wish for the ring gear to fix itself
Viperfitness1 is offline
Old 07-09-2013 | 05:05 PM
johnny,id be very concerned why the ring gear and the starter broke.
mike tkach is offline
Old 07-09-2013 | 09:10 PM
cheap ass china gear reduction starter, should had known happened before went to a msd starter never happened again,
Old 07-09-2013 | 09:13 PM
andy I tried that, its my own fault, should had put better brand instead of that cheap ass crap, live and learn tho, now to pulling the engine phuckin pos.
Old 07-09-2013 | 09:14 PM
i knew i had to pull it was just wondering if i could slide it out of the coupler and raise it instead of pulling the engine.
Old 07-10-2013 | 12:28 AM
the drive needs to come ,,once its off and if you have room in the boat you can just spin the engine to ermove the bellhousing and flywheel,,the ring can be bought at napa and you can just knock the old one off with a hammer and chisel and warn the new one up with a map torch and drop it on..once it cools install flywheel..
FIXX is offline
Old 07-10-2013 | 02:15 AM
waughwax is offline
Old 07-10-2013 | 12:47 PM
blue thunder's Avatar
Once you get the flywheel and starter replaced you should remove the spark plugs and see if water blows out of them when cranking the starter. Or else you may end up replacing an expensive US made starter next.... or worse.
blue thunder is offline
